I Have got almost everything to work properly exept the temperature is offset by minus 10 degrees of my chosen temperature. for example if i set temp to 210C the extruder will stay at 200. And if i chose 180 it will stay at 170...
I have tried to replace hotend and temp sensor but its behaving in the same way so i dont think it is a hardwere.
In Repetier-Host V1.6.0 there is a setting called Temperature offset in the print settings/extruder menu. I have tried to change that value from 0 (default value) to +10 and also to -10. But that doesnt change anything.
So I have tried to se if I could find something in the firmware (Plusa I3 A sanguinololu) that could fix the issue.
I have tried following changes without any succsess. (And i know im succesfully upploadnig frimware settings since i have changed max step limitation)
in configuration.h i have tried to change:
(173) #define MAX_REDUNDANT_TEMP_SENSOR_DIFF 10 (to 0 without any difference)
in configuration_adv.h i have tried to change:
(57) #define TEMP_SENSOR_AD595_OFFSET 0.0 (to 10 and -10 without any difference)
I need help to solve this problem since I cant find a solution to this problem.
Thanks Anders_F
