Iduino Yun - can't upload sketch
Scott
Post by Scott »
I have an Iduino yun. I can log into the webpage and I can ssh in. But I can't upload sketches from the Arduino IDE.
1. I'm using the latest IDE
2. I can see the board port "Iduino at 192.168.1.19 Arduino Yun" on the IDE
3. The Iduino is configured for Arduino board (that's the base board I'm using) via the webpage
4. I have the board type selected in the Arduino IDE, and the hardware profile added so it reads "Arduino Uno --Iduino Yun" as board type.
When I try to upload, it asks for the password, then it sits there "uploading" for a long time, then spits out this error:
Code: Select all
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
processing.app.debug.RunnerException
	at cc.arduino.packages.uploaders.SSHUploader.uploadUsingPreferences(SSHUploader.java:144)
	at cc.arduino.UploaderUtils.upload(UploaderUtils.java:78)
	at processing.app.Sketch.upload(Sketch.java:1187)
	at processing.app.Sketch.exportApplet(Sketch.java:1160)
	at processing.app.Sketch.exportApplet(Sketch.java:1132)
	at processing.app.Editor$DefaultExportHandler.run(Editor.java:2409)
	at java.lang.Thread.run(Thread.java:745)
Caused by: com.jcraft.jsch.JSchException: session is down
	at com.jcraft.jsch.Session.openChannel(Session.java:843)
	at cc.arduino.packages.ssh.SSH.execSyncCommand(SSH.java:59)
	at cc.arduino.packages.ssh.SSH.execSyncCommand(SSH.java:51)
	at cc.arduino.packages.uploaders.SSHUploader.runUploadTool(SSHUploader.java:158)
	at cc.arduino.packages.uploaders.SSHUploader.uploadUsingPreferences(SSHUploader.java:135)
	... 6 more
Any suggestions?
Thanks,
Scott
Re: Iduino Yun - can't upload sketch
Hi,Scott
Have you done all of this yet?
