Bad printing surface above support material
Pillar201
Post by Pillar201 »
Hi, Im an owner of a Prusa i3 pro b Printer. Im using Repetier Host 1.6, 1.75 Fillament, 0.4 Extruder nozzle. My main issue is that the support structures wont build correctly causing bad surface above support material. I would like to be informed about the best slicer Settings for the support material to achieve the best result. Also the support material is impossible to be removed easily causing model destructions. Thanks in advance.
Here ive got some pictures that will help you out:
file:///C:/Users/Marios/Desktop/IMG_20160918_232017.jpg
file:///C:/Users/Marios/Desktop/IMG_20160918_232049.jpg
file:///C:/Users/Marios/Desktop/IMG_20160918_232038.jpg
file:///C:/Users/Marios/Desktop/IMG_20160918_232031.jpg
Re: Bad printing surface above support material
I'm afraid i can't see your picture successfully...
I think if you keep the two setting default values,i guess it's easier to remove it:
Or you can use Cura,cuz there are more settings about support material.
