I had a problem with the extruder not working and through the supplier I had an email which fixed the problem by switching E0 and E1 pins in the pins.h file. Now, I have a problem with the z axis steppers not responding to the endstop switch. I've checked the switch and it's ok. This has only happened since I reloaded the I3 pro b firmware. Also, when I upload the firmware to the GT2560 there are "Invalid library" messages.
Anyone had this problem?
Z axis steppers going past endstop
Re: Z axis steppers going past endstop
You said you reload the firmware,what version Arduino did you use?
I'm not sure if you've upload it successfully?
Could you show me with some pics or videos?
I have a feeling that is what might be the problem. I have Arduino 1.6.1.
Try Arduino 1.0.1:
https://www.arduino.cc/en/Main/OldSoftw ... ases#1.0.x
Thanks William
Arduino version 1.0.1 worked perfect. No Orange messages as it uploaded and no errors at the end. Just a simple upload. i re-homed the machine afterward and it was perfect.
