I get this error wen im try to upload the firmware
ANy solution for this
Arduino: 1.6.11 (Windows 7), Πλακέτα:"Arduino Mega ADK"
from sketch\BlinkM.cpp:5:
#define X_MAX_PIN -1
#define X_MAX_PIN 24
#define Y_MAX_PIN -1
#define Y_MAX_PIN 28
sketch\pins.h:2958:0: warning: "Z_MAX_PIN" redefined
#define Z_MAX_PIN -1
sketch\pins.h:1375:0: note: this is the location of the previous definition
#define Z_MAX_PIN 32
from sketch\ConfigurationStore.cpp:1:
from sketch\thermistortables.h:4,
from sketch\Configuration.h:792,
from C:\Users\htpc\Desktop\Marlin-PI3_Pro_B\Marlin\Marlin.ino:33:
from sketch\MarlinSerial.cpp:23:
sketch\Marlin_main.cpp:2667:36: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
from sketch\cardreader.h:8,
struct fpos_t {
c:\program files (x86)\arduino\hardware\tools\avr\avr\include\stdio.h:950:33: note: 'fpos_t' has a previous declaration here
exit status 1
Αυτή η αναφορά θα παρείχε περισσότερες πληροφορίες με
"Εμφάνιση πλεονάζουσα έξοδος κατά τη σύνταξη"
Επιλογή από το Αρχείο -> Προτιμήσεις.
Firmware problem i3 pro b
Re: Firmware problem i3 pro b
Try Arduino 1.0.1:tsounakas wrote:I get this error wen im try to upload the firmware
struct fpos_t {
exit status 1
https://www.arduino.cc/en/Main/OldSoftw ... ases#1.0.x
It works now thanx
