Hi all,
could anybody tell me if Assembled JIETAI Dual-head Hotend could be mounted on Prusa I3 M201 and in this case what modification should be done.
If not, I need to know on what printer inside in GEEETECH stock could be mounted JIETAI Dual-head Hotend.
Assembled JIETAI Dual-head Hotend on Prusa I3 M201
Re: Assembled JIETAI Dual-head Hotend on Prusa I3 M201
Hi,Ecos
You mean this dual extruder?
http://www.geeetech.com/mk8-dual-extruder-p-921.html
You can refer to this post:
http://www.geeetech.com/forum/viewtopic ... 074#p30074
Re: Dual-head Hotend on Prusa I3 M201
No sorry, I meant Dual-head Hot End
http://www.geeetech.com/wiki/index.php/ ... ad_Hot_End
It's possible to be used on a Prusa I3 M201 already mounted? Firmware, hardware are compatible?
It can replace the 2-in-1 hotend,but something you have to know:ECOS wrote:No sorry, I meant Dual-head Hot End
1.The printer lose its MIXER function after that.
2.You have to design the holder for the new hotend.
3.You should use a Cartridge heater whose rated voltage is 24V,the one on the new hotend is 12V 30W.
4.The firmwre is compatible.
