When I print something suddenly after 5% or 6%  it stops to push filament into nozzle, like motor stops to work.
I tried than again new print and it is the same, I tried motor with X axis and works.
I have also raised extruder votalge to 1.08V and doesn't help.
What can be wrong?
Nozzle is not clogged.
						Weak stepper motor
Re: Weak stepper motor
1.Can you extrude the filament with your hand?
2.You can try swapping the extruder driver with other axes,and remove the fan on extruder to observe how it turns to not feeding status.
