3d touch probe huge problems
Posted: Fri Oct 28, 2016 1:41 pm
Hey all
i just installed(what a nightmare if you have repetier and no manual)
everything looked great till i noticed i couldnt set my nozzle offset. it was just never quite right. then i got a print to start after reseating everything and dismantling the probe. midway through the second layor i noticed the pin was dragging and causing trouble. i tried to manually push it bk up, but it was solid. after investigating i found the allen key adjuster on top had moved real far down and now my min position was below the nozzle. i checked to make sure the pin was firmly in his shrink wrap rebuilt and restarted, only to have the same problem on the next print. this happening to anyone else? any solutions? the back looks kinda loose, should i tighten it up?
thanks
mevo
thanks
mevo
