Hi, i get an error, Err Min Temp, seems the thermistor has an malfunction.
But i change the thermistor from headbed and extruder.
the extruder thermistor with the headbed connection it works.
the headbed thermistor on the port from the extruder -->malfunction
It seems the connector on the board has a malfunction.
But the board is prepared for 2 extruders, how can i change the Pin from the first extruder thermistor connector to
the second connector for the second extruder.
for explanation i want to measure the extruder temperature with the second connector for the additional extruder,
i hope this will work
i dont want a second extruder.
Can you help me to change the ports in the firmware?
greets Alex
thank you!
Alex
						Problem Err Min Temp.
Re: Problem Err Min Temp.
Hi,Alex
You can refer to this post to make some modifying:
http://www.geeetech.com/forum/viewtopic ... 20&t=18020
				facebraker
Hello William,
i found it, few hours after my post.
It did not leave me any peace,I didn't want to wait for the answer.
It works fine, my Printer works again.
Thank you for your reply and assistance!
Greets from Germany!
Alex
Alex
Alex,congratulations!
