Problem on prusa i3 pro b
jauffrey
Post by jauffrey »
hello
I have a problem with the gt2560, Sunday i finish to build the printer and now i'm calibrate the printer yesterday the
printer functioned well ybut today the limit switch Y doesn't work is supplying power and when it is activate this power cut but the motor continue to run as if the limit witch not activate
What is the problem and how can i fix
Best regards Jauffrey
Re: Problem on prusa i3 pro b
You'd better check if the Y endstop(the two ends) has no a good connection to the board and the connector.
If it still exists after that,you can swap Y endstop with X/Z endstop to check if it is broken...
jauffrey
Post by jauffrey »
I try this is not the limit switch is from the board the orther limit switch work on the board just the min y doesn't work
Hello Jauffrey,
What exactly do you mean?
The Y endstop doesn't work or the Y_min slot doesn't work?
jauffrey
Post by jauffrey »
The y min slot on the board doesn't work, the endstop work perfectly
Jauffrey
You can try swapping the pins of Y_min with the pins of Y_max,refer to this:
http://www.geeetech.com/forum/viewtopic ... 20&t=18020
jauffrey
Post by jauffrey »
i try to swap the Y MIN with the Y max , the card reconize the endstop but the Y motor still not stop when the the Y endstop is hit, i try swap the pololu a4988 with an orther and still do the same error and the endstop is good
i thinks the problem came from the GT2560 board
Jauffrey
I mean you can exchange the pins setting about Y_min and Y_max slots in the firmware:
Upload the firmware modified for you and plug Y endstop to Y_max slot on the board to see how it works:
Marlin-PI3_Pro_B.zip
(299.31 KiB) Downloaded 415 times
jauffrey
Post by jauffrey »
Yes i did this but still do the same error
Jauffrey
That's so weird...
The Y_max slot was broken too?
You can try swapping the pin of Y_min with Z_max/X_max in the firmware like the post i attach to you:
And see if there is a difference.
