SD card not recognized
I tried to us the SD memory card, formatted one and copied the project.  When I plugged it in it did see the card.
						Re: SD card not recognized
1.You can restart your printer after plugging it.
2.If it still fix it,you can upload the firmware again.
3.If all the above are not working,change another SD card to have a try.
I had tried those recommendations. Still not recognized. Firmware 1.1.0 A  Need to confirm the correct location I can download the latest from, and the needed instructions.
1) I had downloaded Flash_Loader_Demonstrator_V2.6.0
2) Ran the program to upload the bootloader.bin
3) Removed the jumper
4) Ran HyperTerminal
This is where the screen departed from the STM32Pro Firmware burning steps.docx
It appears I am expected to select from a menu, option 1 then option 2 in order to upload the Rostock301_V1.0.02.bin file with the HyperTerminal program. After each attempt, nothing was uploading, so I canceled the operation and pressed the return key and got an OK back from the board.
I can continue to use the unit but can not use the SD card.
Did you read it?
http://www.geeetech.com/forum/viewtopic ... 20&t=18167
Bonjour,
Est-ce que votre problème est réglé ?
Si oui, comment avez-vous réglé le problème ?
Est-ce qu’aujourd'hui vous réussissez de belles impressions 3D avec votre imprimante ?
Si vous avez d'autre type de problème, voir des pistes de solution dans le sujet suivant :
http://www.geeetech.com/forum/viewtopic ... 27&t=18578
Cordialement,
L'ami René
Is your problem resolved?
If so, how did you solve the problem?
Are you able to make beautiful 3D prints with your printer today?
If you have any other type of problem, see solution tracks in the following topic:
Cordially,
Friend René
Bonjour,
Cordialement,
L'ami René
Cordially,
Friend René
One for all and all for one !
