Extruder motor doen't works correctly
veromero
Post by veromero »
Hi! Im Vero from Argentina!
The extruder of my Geeetech I3 ProB is not working correctly. When I set to extrude 100mm/s It extrude only 10mm/s (but this shows that the motor works), but then when I send it to print the motor of the extruder doesn't move even a little.
I have another extruder so I changed it in order to identificate the problem, but it happens the same thing. So the problem is on the board. Then I changed the controller chip and mesured the pololu but these things are OK..
Someone have any idea what could be the problem? and any solution? Can I do some changes on the frimware and exchange Extruder 1 with extruder 2 pin or something like that?
I really appreciate your help :D
phildarito
Re: Extruder motor doen't works correctly
Post by phildarito »
Philippe from France
I bought a GEEETech acrylic i3 pro B and I have exactly the same problem.
I tried with the Z axis motor, with the z axis cable, same problem.
Check the pololu, check the power unit => same problem.
I tried every firmware for the GT2560 in this forum, same problem.
When I change the step/mm for the extruder, same problem.
If I want extrude 100mm (repetier or with the LCD) I only have 14mm :evil:
Dead board or dead firmware ???
Hi,Philippe
1.Did you check the subdivision?
2.Have you tried swapping the driver A4988 with other motor's?
3.Theoretically,you can modify the step/mm in "Control-Motion" and "Control->Store Memory",then the modifying will come into effect next time.
phildarito
subdivision checked
subdivision checked
driver A4988 swapped
step in marlin
step in marlin
step in repetier
step in repetier
next try ?
next try ?
14mm for 100mm asked :(
same try with the new firmware received by mail and same result
veromero
Post by veromero »
Thank you William.. I did all things you say but its still happend the same thing, When I setting on the Repetier to extrude 100mm/min It extrude some 10mm/min and when I send it to print the motor just doesn't move. I change at frimware E0 with E1 and the change it works, but the problem persist!! Im really lost and sourprised ... I change the motor with other motor and its happend the same thing.
Philip the same thing happens to you? If you can solve it please let me know how! I will do the same thing... Im talking with the technical assistance of Geeetech but They still could not solve it...
phildarito
Always the same problem, I think the extruder part of my board is dead.
I swapped the motor, the wires, everything and all of this work fine in the X for exemple, the only answer is dead board.
:evil: :evil: :evil:
veromero
Post by veromero »
Yes.. I think the same... :( .. I swapped the pin of E0 and E1 in refer to this:
http://www.geeetech.com/forum/viewtopic ... 20&t=18020
Thats a really good information that technical suport of Geeetech gave me, but it doesnt work on my case..
phildarito
thank you, I will try soon.
phildarito
I just tried to swap E0 and E1 and it does'nt work with me too :(
veromero
Post by veromero »
We will have to buy another board :? . :cry: hahah
