Extruder stops extruding
Martin01
Post by Martin01 »
I have a lot of Problems with the extruder. After the buying he doesn't work.
He makes sounds like Clogging.
https://youtu.be/641iKPCryQY
I have checked the Inliner thats was not ok but a correct doesn't fix the problem
http://i.imgur.com/xcrMYcj.jpg
i have tested various Nozzle
i have tested various filament gear
I have make mor prressure but it don't helps
https://youtu.be/flBJIXbPp10
it stops an need more pressure at normal extruding.
more pressure isn't possible because the arm was on max psosition and with more waschers i dont can mount the spring.
The nozzle isn't clogged. i hav make the test like (viewtopic.php?f=19&t=17097)
Martin01
Re: Extruder stops extruding
Post by Martin01 »
It looks like if i forund the Problem.
The pin wich is the axle from the Bearing in the Eeder wich is pressing the filament to the gear is broken. i have it provisionally replaced by an Screw and it looks like if it works yet.
But the screw is not a long term solution.
Could you take a picture of the broken part?
