Rostock 301 - no connection to printer if lcd is connected
perterpaulsen
Post by perterpaulsen »
Hey,
if the lcd is unplugged, I can connect with repetier to the printer. If the display is connected, I cannot get a connection to the printer with either repetier or HyperTerminal. If the lcd is connected, also the hotend fan is not running, but if the display is unplugged, the hotend fan is running.
When the lcd is plugged in, it displays two rows with black blocks.
Can anyone help me make sense out of it?
Thanks!
Lami René
Re: Rostock 301 - no connection to printer if lcd is connect
Post by Lami René »
Bonjour,
You can find the original text into English following this original French text.
Vous trouverez le texte original traduit en anglais à la suite du présent texte originale en français.
Est-ce que votre problème est résolu ?
Cordialement,
L'ami René
Is your problem resolved?
Cordially,
Friend René
One for all and all for one !
Maybe there is something wrong with your board...
You can try unplugging all the cables on the board except the power cable and LCD cable,and see if the LCD works fine.
