I ordered a Geeetech Acrylic Prusa I3 pro B, after building it (cf. https://www.geeetech.com/Documents/Geeetech prusa I3 pro&pro B building instruction.pdf) i installed drivers and software Repetier on my computer (cf. https://www.geeetech.com/Documents/Geeetech Prusa I3 pro&pro B User Manual.pdf)
2 problèmes appeared :
-The first one is that a motor (X axis) turn in the wrong direction. So I tried to reopload the firmware (as told in section 8.2), problem is that arduino gave me the followoing error :
Code: Select all
Arduino : 1.6.12 (Windows 7), Carte : "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
from sketch\thermistortables.h:4,
from sketch\Configuration.h:792,
from C:\Users\titan\Documents\Arduino\Marlin-PI3_Pro_B\Marlin-PI3_Pro_B\Marlin\Marlin.ino:33:
#define X_MAX_PIN -1
#define X_MAX_PIN 24
#define Y_MAX_PIN -1
#define Y_MAX_PIN 28
sketch\pins.h:2958:0: warning: "Z_MAX_PIN" redefined
#define Z_MAX_PIN -1
sketch\pins.h:1375:0: note: this is the location of the previous definition
#define Z_MAX_PIN 32
sketch\Marlin_main.cpp:2667:36: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
from sketch\cardreader.h:8,
struct fpos_t {
c:\program files (x86)\arduino\hardware\tools\avr\avr\include\stdio.h:950:33: note: 'fpos_t' has a previous declaration here
exit status 1
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
-The other problem is that extruder thermometer tells something like 350°C, (He is cold). So I have the impression that this blocks all the printer. I can see the message Err: MAXTEMP on the LCD screen also.
Is it possible to set (calibrate) the thermometer manually, or is it dead ?
Thanks a lot in advance for helping me! Best regards,
