Gt-2560 to GTM32 rev b
Trying to upgrade my Rostock dual extruder. I purchased a 3in1 hot end and a GTM-32 rev b board. I have everything installed and when I load the M301 firmware it loads successfully, but does not work. The LCD 2004 shows two lines of blocks instead of the normal display. If I load firmware for the M201 I3 the firmware loads ok and the display is proper. Of course the printer doesnt work as mine is a delta and not an I3. Any help is appreciated.
Re: Gt-2560 to GTM32 rev b
Surely someone has tried to load firmware on this board.....the demo flash loader appears to be loading the firmware and will verify, but I get no indication on the LCD that the printer is working. Again I can load V 1.0.5 hex and the display works normally, but it is the wrong type of printer.
Hi,man
I'm afraid you can't use 3-in-1-out hotend on GTM32 RevB, i guess you noticed the Rostock 301(the board on it is GTM32 Pro,not GTM32 RevB).
Can I buy a GTM32 Pro board. It is not listed on web page .
Hi,@divemasterbill
You can contact the sales(sales@geeetech.com) to learn more about it.
printing 3D with M201 Geeetech
