Bowden Tube Removal
Veenoh
Bowden Tube Removal
Post by Veenoh »
What is the right way to remove a Bowden tube from the hot end. I think the filament should be heated and retracted. Then the hot end should be allowed to cool and then the tube can be pulled out. Is this correct?
Thanks.
--Dave
Cup
Re: Bowden Tube Removal
Post by Cup »
Hi,Dave
You just need push down the blue item on the hotend to the lowest,then you can make it.
Veenoh
Post by Veenoh »
Thanks, Cup. I know how to pull out the tube. My question regards whether and when to heat or cool the filament to free up the tube and also prevent clogging the nozzle.
