3D touch GT2560
Posted: Fri Dec 16, 2016 4:38 am
by Laeriut
Hi all
I have the 3D touch leveling sensors. I have the GT2560 board but not like in the description. So now i dont know how to wire the sensors. I cant solder the 3 pins on ZMAX because there are only 2. How can i wire the sensors on the board? Show attachement, this are my endstops on the board.
Re: 3D touch GT2560
Posted: Fri Dec 16, 2016 9:23 am
by Cup
Laeriut wrote:Hi all
Did you read the User Manual of 3D touch?
You need remove the Z_max connector then solder another 3-pin connector to replace it,otherwise you can't get your sensor working i guess:
Re: 3D touch GT2560
Posted: Fri Dec 16, 2016 2:18 pm
by Laeriut
Yes i read the manual. But i have a different board... i dont have 3 connectors on the board to solder a 3pin header... look at the picture, my endstop connectors are all facing parallel to the board. On the board in the description they are 90° degrees otherwise.
Re: 3D touch GT2560
Posted: Fri Dec 16, 2016 7:58 pm
by Laeriut
I fixed my Problem. I am now able to use the sensors (without soldering anything).
Re: 3D touch GT2560
Posted: Sat Dec 17, 2016 4:06 pm
by Cup
Nice work!
How did you make it?
Re: 3D touch GT2560
Posted: Mon Dec 19, 2016 6:04 am
by Laeriut
5v from pin of the Stepper driver and GND and control signal from Z-MAX :)
Re: 3D touch GT2560
Posted: Wed Jan 25, 2017 6:25 pm
by Akroon
Laeriut wrote:5v from pin of the Stepper driver and GND and control signal from Z-MAX :)
That sounds like a great solution, cause I'm to scared too solder on my board.
is it possible for you two take a photo of your wiring? Which stepper driver pin you used?
Re: 3D touch GT2560
Posted: Thu Apr 13, 2017 9:52 pm
by Romuald
[quote="Laeriut"]5v from pin of the Stepper driver and GND and control signal from Z-MAX :)[/quote]
I have the same issue can you take a picture of the wires please ?
EDIT : Connection wires solved for me, i have found a pdf files who have an update picture for the "GT2560 Rev a+" board, see the picture below for understand how to connect
[img]http://i.imgur.com/E0t34VU.png[/img]
Re: 3D touch GT2560
Posted: Tue May 02, 2017 8:40 am
Hi,there are 3 pins on ZMax 's location.You just need to replace the 2pins' socket with 3pins.
