hi,
the first printing is the result.
Wire PLA working temperature between 180 and 220 degrees.
I put my printer configuration.
What should I change to print better?
Thank you
First Print PLA
First Print PLA
- FullSizeRender 2.jpg (104.19 KiB) Viewed 4648 times
- DSC_0336.JPG (251.33 KiB) Viewed 4648 times
- DSC_0334.JPG (239.32 KiB) Viewed 4648 times
- DSC_0333.JPG (272.79 KiB) Viewed 4648 times
- IMG_3864.JPG (128.24 KiB) Viewed 4648 times
- IMG_3863.JPG (121.57 KiB) Viewed 4648 times
- IMG_3862.JPG (115.48 KiB) Viewed 4648 times
- IMG_3861.JPG (118.2 KiB) Viewed 4648 times
- IMG_3860.JPG (127.13 KiB) Viewed 4648 times
- IMG_3859.JPG (123.51 KiB) Viewed 4648 times
- IMG_3858.JPG (121.54 KiB) Viewed 4648 times
- IMG_3857.JPG (131.76 KiB) Viewed 4648 times
Re: First Print PLA
Did you modify some settings in menu "Control" ?Use the default settings first.
Then refer to this article:
https://www.simplify3d.com/support/prin ... eshooting/
