Settings and Control windows are too small
Veenoh
Post by Veenoh »
The windows that come up when the Settings and Control buttons are pressed are too small. The buttons at the bottom are almost completely cut off.
Admin
Re: Settings and Control windows are too small
Post by Admin »
Veenoh wrote:The windows that come up when the Settings and Control buttons are pressed are too small. The buttons at the bottom are almost completely cut off.
Hello Veenoh
Thanks for your feedback, we will enlarge it next time.
Uzi3L
Post by Uzi3L »
yep was going to comment the window pop ups are not scrollable or re-sizeable pretty useless atm cause you can't use the buttons or settings.
macinblack
Post by macinblack »
Same here, I can't see the buttons...
Macflame
Post by Macflame »
The same here.
consta
Post by consta »
Hi I can't setting with my PI3_C Pro, have problems with the usb port I select usb port #4 and don't save my config, and the some menu option I can see.
Veenoh
Post by Veenoh »
I was able to connect to my G2s and control a few things using Parallels on my Mac. That is a good sign. However, I'm coming across many more windows that are cut off at the bottom so it is not worth going any further for now.
Macflame
Post by Macflame »
I am getting the same thing. Only the very top part of the boxes are showing but they do respond when you click on them.
No text is showing in the part boxes.
ADVALL
Post by ADVALL »
Why bother with this cut down, unfriendly and buggy program. Repetier works!!!!
Easy print should be only introduced when all simple functions actually work or bugs are quickly fixed. Not to see the full dialog box is disgraceful!!!
I think Geeetech should retire from software efforts,
otto
Post by otto »
My printer is Prusa I3 X 3D printer DIY kit I have lost the SD card I need the marlin kofigurations file which is on the map to adjust the parameters please left me the file
Or please the complete contents of the sd map me left here without I come no further
otto
