I have a prusa I3 pro x with a gt2560 board. I added a second mk8 extruder and installed a motor driver chip and got everything connected. I uploaded the I3 pro x duel extruder firmware. The problem I'm have is only extruder #1 turns. Extruder #2 does not spin. does anyone have any insight on this or a way to get it working?
Thanks,
Jason
Prusa I3 Pr X duel extruder
Re: Prusa I3 Pr X duel extruder
Hi,Jason
Did you heat up all the extruders when testing extruder motors?
And you can refer to the following post to make some troubleshooting:
www.geeetech.com/forum/viewtopic.php?f=19&t=17097
Yes i made sure that both hotends were heated up to 185
So did you check everything(the driver,cable,stepper motor) in that post?
