Temperature pb
Basque
Temperature pb
Post by Basque »
Hi, Sorry for my english, im french, i've Got à pb with my New i3 pro-b with mk8 extruder, my printer have 20 days, and all was good but its 2 days ago my printer dont work correctly, she print bad like not enouth température in extruder, so í put more and its beter but to have same print like many days ago, with same filament, i must put at 260 and print at 40mm/s at 0.2, i look for thermostat and its in her place, can you help me?
bang
Re: Temperature pb
Post by bang »
Maybe the extruder temperature is not stable when printing...
Or the thermistor inside it is not tight enough?
Basque
Re: Temperature pb
Post by Basque »
Hi thanks for your answer, the température don't have fluctuation, when i printing in 260 with pla i have à corect result so the temp don't change, for the thermistor i try to fix him again inside and i tight him, another solution?
bang
Re: Temperature pb
Post by bang »
So strange...
Did you print in PLA?
If you did,the temperature is too high for it.
You can try heating up your extruder to its original temperature(190-210) then extrude the filament with your hand to see if it can come out smoothly...
I'm suspecting the hotend may have a clogging issue or the filament has a problem...Did you change your filament before this happened?
Basque
Re: Temperature pb
Post by Basque »
Yes, im sure is pla its many days ago i print pla and abs with good temps, now i must put 260 for pla in slow print speed to print correctly, when i put 190-210° with pla the filament is not enouth "liquid" to go out correctly of the nozzle, and extruder do clack clack because the filament don't go out correctly
bang
Re: Temperature pb
Post by bang »
If you have printed in PLA and ABS,i guess maybe the nozzle or the hotend is not in the good condition as they used to be..
Maybe something wrong with them.You can have a check on them.
Basque
Re: Temperature pb
Post by Basque »
Yes i try to clean thé nozzle and other part, but i brock à part of feeder, so í do an order to repar all
