I received a Rostock 301 printer three days ago. I assembled it and adjusted everything according to the user manual. It took about 15 hours. I adjusted the level and its ok.
When I started to print the elephant model, the hotend scratched with the printing bed and the filament is not out anymore. I don't know if it's blocked or the hotend is damaged.
Does anybody have any idea about how to solve the problen or should I buy another hotend?
Best regards,
Hotend problem
Re: Hotend problem
Maybe you can heat up the extruder first then extrude the filament(try 3 paths) with your hand to have a look.
Re: Hotend problem
I could let the filament go, but it is very slow (not fluent) and is not sticking with the hot bed. I'm using ABS with 235 C and 95 C.
Best regards,
Best regards,
Re: Hotend problem
You can add some glue or blue tapes on the heatbed for the sticking issue,and i think you'd better test PLA first.Then test ABS if PLA is normal.Mostafa wrote:Hi,
Best regards,
How do you like it?
