Prusa I3 X Buid
Synint
Prusa I3 X Buid
Post by Synint »
I have just completed the build of the Prusa I3 X Pro and have the following issues:
1. End stopper on the Y carriage not working.
2. Extrude carriage on the X Axis running in the wrong direction.
Anyone kind enough to respond could you please keep any advice as simple as possible as this is the first build project I have undertaken and have no electronic or programming knowledge. However any advice would be much appreciated.
Cheers,
John
bang
Re: Prusa I3 X Buid
Post by bang »
Hi,John
Did you fix it?
PrinterHacker
Re: Prusa I3 X Buid
Post by PrinterHacker »
Hi I had similar problem with other problems. When I installed the firmware every thing worked ok. If you want to install Firmware for your printer please follow the instruction as directed by Geeetech step by step. You must use their firmware and not from GitHub. The GitHub firmware requires lot of tweaking and you may not get support from Geeetech if you do.
Please note, if you install Geeetech firmware you must use Arduino IDE version 1.6.11 and not 1.6.12 or above. You will have to download older version of Arduino from Arduino web site.
Good luck.
