Major printer issue
pamato
Major printer issue
Post by pamato »
I have a Geeetech Aluminum i3A that I just assembled and have a question about.
I am having issues getting it to print.
When I set my machine to: Prepare -> Move Axis -> Move 1mm -> Move Z axis and turn the dial to 2mm the Z axis moves up 12.64mm
That doesn't seem right.
Here is some more information on my problem.
This was a print of the Standard Cube 1ML from Thingiverse http://www.thingiverse.com/thing:17003
https://goo.gl/photos/JMyoAKuKeBNNdC696
Here is a close up of the results:
https://goo.gl/photos/fdptcZWqyZNvT8Wr7
Lastly here are my Cura settings for that print
https://goo.gl/photos/PhBCUyWMaFLErpPv9
Modified the firmware to change the default_axis_steps_per unit based on the z axis calibration formula from 2650 to 405.
Recompiled and uploaded to printer and the Z axis still moves 6.32mm for every one commanded mm of travel.
I am out of things to try to get this printer to print.
