Accelerometer ADXL345
Hi,I'm using arduino IDE to program the accelerometer ADXL345, I have 5 accelerometers, but 2 of them give me values differents, How can I know if the accelerometers are damaged or if need different method to calibrate ?
Thanks.
Thanks.
- techsupport
- Site Admin
Re: Accelerometer ADXL345
Hi, Ivan, thank for your post, please kindly try the following code.Ivan wrote:Hi,I'm using arduino IDE to program the accelerometer ADXL345, I have 5 accelerometers, but 2 of them give me values differents, How can I know if the accelerometers are damaged or if need different method to calibrate ?
Thanks.
Code: Select all
//Add the SPI library so we can communicate with the ADXL345 sensor
#include <SPI.h>
//Assign the Chip Select signal to pin 10.
int CS=10;
//This is a list of some of the registers available on the ADXL345.
//To learn more about these and the rest of the registers on the ADXL345, read the datasheet!
char POWER_CTL = 0x2D; //Power Control Register
char DATA_FORMAT = 0x31;
char DATAX0 = 0x32; //X-Axis Data 0
char DATAX1 = 0x33; //X-Axis Data 1
char DATAY0 = 0x34; //Y-Axis Data 0
char DATAY1 = 0x35; //Y-Axis Data 1
char DATAZ0 = 0x36; //Z-Axis Data 0
char DATAZ1 = 0x37; //Z-Axis Data 1
//This buffer will hold values read from the ADXL345 registers.
char values[10];
//These variables will be used to hold the x,y and z axis accelerometer values.
int x,y,z;
void setup(){
//Initiate an SPI communication instance.
SPI.begin();
//Configure the SPI connection for the ADXL345.
SPI.setDataMode(SPI_MODE3);
//Create a serial connection to display the data on the terminal.
Serial.begin(9600);
//Set up the Chip Select pin to be an output from the Arduino.
pinMode(CS, OUTPUT);
//Before communication starts, the Chip Select pin needs to be set high.
digitalWrite(CS, HIGH);
//Put the ADXL345 into +/- 4G range by writing the value 0x01 to the DATA_FORMAT register.
writeRegister(DATA_FORMAT, 0x01);
//Put the ADXL345 into Measurement Mode by writing 0x08 to the POWER_CTL register.
writeRegister(POWER_CTL, 0x08); //Measurement mode
void loop(){
//Reading 6 bytes of data starting at register DATAX0 will retrieve the x,y and z acceleration values from the ADXL345.
//The results of the read operation will get stored to the values[] buffer.
readRegister(DATAX0, 6, values);
//The ADXL345 gives 10-bit acceleration values, but they are stored as bytes (8-bits). To get the full value, two bytes must be combined for each axis.
//The X value is stored in values[0] and values[1].
x = ((int)values[1]<<8)|(int)values[0];
//The Y value is stored in values[2] and values[3].
y = ((int)values[3]<<8)|(int)values[2];
//The Z value is stored in values[4] and values[5].
z = ((int)values[5]<<8)|(int)values[4];
//Print the results to the terminal.
Serial.print(x, DEC);
Serial.print(',');
Serial.print(y, DEC);
Serial.print(',');
Serial.println(z, DEC);
delay(500);
//This function will write a value to a register on the ADXL345.
//Parameters:
// char registerAddress - The register to write a value to
// char value - The value to be written to the specified register.
void writeRegister(char registerAddress, char value){
//Set Chip Select pin low to signal the beginning of an SPI packet.
digitalWrite(CS, LOW);
//Transfer the register address over SPI.
SPI.transfer(registerAddress);
//Transfer the desired register value over SPI.
SPI.transfer(value);
//Set the Chip Select pin high to signal the end of an SPI packet.
//This function will read a certain number of registers starting from a specified address and store their values in a buffer.
//Parameters:
// char registerAddress - The register addresse to start the read sequence from.
// int numBytes - The number of registers that should be read.
// char * values - A pointer to a buffer where the results of the operation should be stored.
void readRegister(char registerAddress, int numBytes, char * values){
//Since we're performing a read operation, the most significant bit of the register address should be set.
char address = 0x80 | registerAddress;
//If we're doing a multi-byte read, bit 6 needs to be set as well.
if(numBytes > 1)address = address | 0x40;
//Set the Chip select pin low to start an SPI packet.
//Transfer the starting register address that needs to be read.
SPI.transfer(address);
//Continue to read registers until we've read the number specified, storing the results to the input buffer.
for(int i=0; i<numBytes; i++){
values[i] = SPI.transfer(0x00);
//Set the Chips Select pin high to end the SPI packet.
Email: forum@geeetech.com
Hi, yes, I used this code and for calculate the angle, add this :
int xAng = map(x, minVal, maxVal, -90, 90);
int yAng = map(y, minVal, maxVal, -90, 90);
int zAng = map(z, minVal, maxVal, -90, 90);
x = RAD_TO_DEG * (atan2(-yAng, -zAng) + PI);
y = RAD_TO_DEG * (atan2(-xAng, -zAng) + PI);
z = RAD_TO_DEG * (atan2(-yAng, -xAng) + PI);
I have correct values with 3 accelerometers from 0 to 360 º ,but with 2 accelerometers the values are bad , Is possible that the acelerometers are damaged ?
- techsupport
- Site Admin
we verify your code it shows error,Ivan wrote:Hi, yes, I used this code and for calculate the angle, add this :
sketch_mar08a:0: error: 'x' was not declared in this scope
sketch_mar08a:0: error: 'minVal' was not declared in this scope
sketch_mar08a:0: error: 'maxVal' was not declared in this scope
sketch_mar08a:1: error: 'y' was not declared in this scope
Did you use the code we provide to test?
Hi, I take the min and max values from your code, and put these values in this code.
With this I have the angles, But this only function with some accelerometers, I don't know if the others are damaged or maybe need calibration, can you help me?
#include <SPI.h>
int CS=53;
char values[10];
int x,y,z,res;
int minVal = -253 ;
int maxVal = 362 ;
void setup(){
SPI.begin();
Serial.begin(9600);
void loop(){
Serial.print(',');
Serial.print(',');
delay(10);
values = SPI.transfer(0x00);
#include <SPI.h>
int CS=53;
char values[10];
int x,y,z,res;
int minVal = -253 ;
int maxVal = 362 ;
void setup(){
SPI.begin();
Serial.begin(9600);
void loop(){
Serial.print(',');
Serial.print(',');
delay(10);
- techsupport
- Site Admin
ok, could you please draw a wiring diagram, we will check it out if there someting wrong with it.
Thanks,
Thanks,
Hi, this is the diagram
In the arduino mega 2560, the connection for SPI are: 50 (MISO), 51 (MOSI), 52 (SCK), 53 (SS)
Wow, lots of great info in there. Thanks for taking your time to do that.
saboor
