How do you setup Cura 2.3.1 for Geeetech I3 PROB?
Karas647
Post by Karas647 »
Does any one have the config settings for Cura 2.3.1 for the Geeetech I3 PRO B (acrylic) . It is not listed as a default printer. Any help or settings would be appreciated
Pouly
Re: How do you setup Cura 2.3.1 for Geeetech I3 PROB?
Post by Pouly »
i have used Prusa i3 Mk2 and changed some settings like bed size and nozzle to 0.3 and it worked.
Anyone using another setting ?
Pouly
Post by Pouly »
i don't get any good results with this settings, so if anyone would be kind enough to share their Cura 2.3 - 2.4 settings it would be great
you can try different settings and you'll get the best printing setting for some time. ;)
Pouly
Post by Pouly »
anyone having good settings for Cura 2.4 ?
rotormansa
Post by rotormansa »
I tried printing with the Cura for the first time this past weekend. This was more of an experiment with this slicer program, but Slic3r has been working fine for me. Default setting for Cura produced fair results. Print time is a about half the time it takes Slic3r and using about 50% of the filament. I read some reviews comparing these two slicing programs, Slic3r is much more efficient and better a curves than Cura. Cura will give your extruder motor a work out as it constantly reverses filament through the entire print.
Pouly
Post by Pouly »
Thanks a lot for your tests, are you able to share your settings ?
sarduhirtu
Post by sarduhirtu »
Karas647 wrote: Mon Jan 30, 2017 2:21 am Hi,
Hi buddy, sorry can't help you with that, I only use Simplify3D. But if you get it running and you have some experience you should definitely try Simplify3D which is awesome.
