Can't slice
BigE
Can't slice
Post by BigE »
I tried clicking on the Slicer and I get the following error
Print Slicer Error.png (23.35 KiB) Viewed 20160 times
Windows 7 Enterprise Edition, 64 bit
Re: Can't slice
You can try installing easy print on other disks(not Disk C) to take a look.
BigE
Re: Can't slice
Post by BigE »
Yep. I'm going to install another hard drive in my computer just so that I can use a buggy slicer. :roll:
dart16
Re: Can't slice
Post by dart16 »
Already been stated on this forum that you need admin privileges to write to c:\program files(x86). What is needed is config files to be written to the users documents folder.....
bang
Re: Can't slice
Post by bang »
Indeed it should be...
Chema57
Re: Can't slice
Post by Chema57 »
I also can´t slice. I tried clicking on the Slicer and I get the following error:
I could not find the generated G-code file.
-the slicer had an error an didn´t finish slicing. Check log out put.
-the slicer stores the file with an unexpected filename.
Expected Filename and Location
C:\Users\Chema\AppData\Roaming\easyprint\work\composition.gcode
At first time y could slice without problem more than four files but now is impossible
Re: Can't slice
Is there any hint of the error code?Search on Google maybe help you.
