Prusar i3 Pro C Feeder not working
Nuklearfire
Post by Nuklearfire »
I have Problems wirt my Prusar he moves like he is printing but no material is comming out.
when i push the Filament manualy a little pit comes out.
bang
Re: Prusar i3 Pro C Feeder not working
Post by bang »
Sounds like your hotend has a clogging or something else wrong on it...Or the temperature is not sufficient?What are you using?
Generally speaking,it should have a smooth flow when you push the filament manually?
In addition,you can remove the fan on your extruder to check if you have the filament correctly inserted to hotend.
Nuklearfire
bang wrote:Sounds like your hotend has a clogging or something else wrong on it...Or the temperature is not sufficient?What are you using?
if my hotend has a clogging it doesnt would work wenn i feed manual.
and if the Tempreature wouldnt be high enought it it would not work when i push manually .
i will test it with removing the fan thanks for helping
