mesh leveling latest marlin
In the latest marlin firmware there is mesh levelling. Will there be an update Of The geeetech pro b wich have mesh levelling enabled? I really hope so I hate levelling my bed
Kind regards
Re: mesh leveling latest marlin
Why not try a Auto-bed leveling sensor?
waiting for it to arrive. Also mesh levelling does take 9 or 10 points autolevel just 4. And I can use the sensor for mesh also I think. Sooooo anybody got a work8ng firmware for me??
As far as i know,the current firmware for ProB can only support 4 points...
I use auto leveling on my Pro C with 9 point mesh. I'm using the RCBugFix version of Marlin from a few days ago.
Can't get configuration.h to work with my pro b cab you copy yours and try that one? I'm no good in programming
Try this. You will need to change your sensor offsets and probably a few other things since I'm using a Pro C instead. I also included the pins configuration file for the 3D Touch.
The configuration.h files will not work with the current official, stable release of Marlin or with RC8. I believe it will only work with RCBugFix.
- config files.zip
- (20.23 KiB) Downloaded 712 times
Thanks ill give it a try tonight! Will post my findings here.
@cosmith,
does your config also fit with some small adaptions for the I3X Pro?
I'm also interested to setup the mesh leveling with a cap sensor on my X Pro.
