I have recently purchase and assembled Geeetech i3 pro B 3d printer (2017 version).
X and Y endstops controlled by microswitches work OK. When X endstop microswitch is pressed x axis motor stops and similarly Y microswitch. But when I press Z microswitch the Z axis motor does not stop.
Also, When autohomed it moves to x=0, y=0 z=0 and stops at x=0. y=0 x=5. It is by design?
I have installed the latest firmware (Marlin_p13_pro_b) as per Geeetech instructions.
Has anybody got a solution for these issue?
Z end stop does not work
Re: Z end stop does not work
Solved. The stop end micro switch has to be plugged into "Z-Min".
