Right hand Z axis motor not working
perpetualmetronome
Post by perpetualmetronome »
Hello all,
The right hand motor of the Z axis is not turning; I believe this to be a control board (GT2560) or firmware issue, my diagnosis as follows:
- When moving the Z axis with Repetier Host, only the left hand stepper motor turns
- With Z axis connectors swapped, only the left hand stepper motor turns
- When right hand motor connected to Y axis on control board, the right hand motor turns
So:
- The right hand motor runs fine when connected to a non-Z axis port
- When both Z axis motors are connected to Z axis ports only the left hand motor runs, no matter which motor is connected to which port
I am setting up to flash the firmware, but I was hoping that someone had some experience with this and what might be causing it, as the firmware update is just a guess on my part.
Thanks!
Re: Right hand Z axis motor not working
Hi,I don't think that's firmware's problem and maybe the hardware.
first,check the right hand motor's wiring connection;
second,check if it's stuck;
third,maybe the motor driver A4988 module's problem.
hope you can make it !
perpetualmetronome
Hi William,
Thanks for the reply; the motor and wiring is fully functional:
perpetualmetronome
In addition, when the left hand Z axis motor is disconnected from the control board, the right hand motor runs just fine.
perpetualmetronome
Ok, so I flashed the firmware for the controller board, using the firmware found via this page:
viewtopic.php?f=13&t=17181
And now the printer displays black squares on starting.
Not really very happy. :(
perpetualmetronome
Ok, firmware downloaded via
http://domoticx.com/prusa-i3-geeetech-f ... -4-gt2560/
Which works - and both Z axis motors run correctly.
The firmware downloaded via this page:
http://www.geeetech.com/wiki/index.php/ ... _Resources
Does not work.
then it's my fault,actually the firmware's problem.and thanks for your sharing. :) :)
perpetualmetronome
William wrote:then it's my fault,actually the firmware's problem.and thanks for your sharing. :) :)
Oh, hey, no worries - you replied with a suggestion, which is great! :)
I'm a little concerned that I cannot seem to locate the correct working firmware for the printer on the Geeetech site though. :(
bang
Post by bang »
Did you try the firmware in this post?Check your model before downloading it:
viewtopic.php?f=20&t=17046
Then concerning Z axis issue,you can check this file to make some troubleshooting:
I3 Z axis.zip
(281.49 KiB) Downloaded 455 times
