I get an error if I change fillament size in easyprint.
If I start up program size is at 3mm, if I want to change it to 1.75mm there's comming a red "!" with a message "not an integer" And switch it back to 3mm.
if I put it to 1.75 program will not go further and "hangs"...
Did re-instal, tried it on 3 different pc's all the same.
Is there a solution for this ? .I'm unable to print...
can't change fillament size in easyprint
- bug.jpg (70.43 KiB) Viewed 7874 times
Re: can't change fillament size in easyprint
Here is the latest version,just give it a shot:
http://www.geeetech.net/firmware/EasyPrint.msi
