Y axis pb with G28 after installation of 3D autoleveling
Yann38
Post by Yann38 »
Just installed 3d Autolevel on my Pro B.
However, I have a problem.
When doing a G28 , no prob with X, but axe Y the bed is going in front of me and don't stop till he hurt the end.
Same thing happen with G29.
Any clue to stop this ?
Need I add end stop on Y Max ?
Yann38
Re: Y axis pb with G28 after installation of 3D autoleveling
Post by Yann38 »
Any people to help me ?
I found the origin of PB: when i put the command G28, it is not reseting properly my Y axi.
I send G28 X, i've obtain in the lCD x+0, if i put G28 Y, it is going to Y0 but in the LCD it show me -97, why ?
Yann38
Post by Yann38 »
Issue not solved but work arround found:
I put G28 X, G28 Y, G92 Y97, G29, in my startup script of my Slicer
Then after the G28 Y which i genrating the 97 on the Y axis, I put back to 0 with command G92 Y97, and then after I do the Autolevel ( G29 )
I've also reduce the rectangle of Probe, on the Y axis, 130 instead of 147.
