Hello again.
After a few months using other printer I have decided re start printing with Gs2s. I have ordered and mount the Pro upgrade kit and the result is a quantitative improve in the quality but.... Always must be a "but". One of the first thing that I tried to print is the case for PSU. The problem is when the head goes further 60 or -60 in the axis X or Y. In those positions of the head belts jumps over the motor gears and the noise is terrible. I have try to correct this failure changing the tensión of the belts but doesn't works. Logically the printer loose the correct position of the head and ruins the print. The same issue happen sending command G29 to printer.
Other minor problems are:
1- Don't extrude at the start.
2- I can't get the quality that I saw in others G2s
Could you help me, please.
Thank You.
						Desperate 2
Return to “Feedback&Suggestion”
				Jump to
 - Firmware
 - 3D Printer
 - ↳ Thunder
 - ↳ Mizar Pro
 - ↳ Mizar S
 - ↳ Mizar
 - ↳ Geeetech I3 Pro B
 - ↳ Geeetech I3 Pro W
 - ↳ Geeetech I3 Pro X
 - ↳ Geeetech I3 Aluminum
 - ↳ Geeetech I3 Aluminum Pro
 - ↳ Geeetech I3 Duplicator 5
 - ↳ Geeetech I3 Pro C
 - ↳ Geeetech I3 M201
 - ↳ Geeetech A10 Series
 - ↳ A10T
 - ↳ Geeetech A20 Series
 - ↳ Geeetech A20
 - ↳ Geeetech A20M
 - ↳ A20T
 - ↳ Geeetech A30 Series
 - ↳ A30M
 - ↳ A30 PRO
 - ↳ Geeetech E180 Mini
 - ↳ Geeetech MeCreator2
 - ↳ GiantArm D200
 - ↳ Geeetech Delta Series
 - ↳ Geeetech DP200 Series
 - 3D Printing Software
 - ↳ Software
 - ↳ Wifi Box
 - ↳ Bug report
 - ↳ Download
 - Hardware
 - ↳ 3D Printer Hardware
 - ↳ Stepper Motor
 - ↳ Control Board
 - ↳ Extruder
 - ↳ Hot bed
 - ↳ LCD Panel
 - ↳ Power Supply Unit
 - ↳ Assembly
 - ↳ Others
 - Print Quality
 - Resoures Sharing
 - Feedback&Suggestion
 - Project Talent Show
 - Other Discussion
 - ↳ Leveling Guide
 - ↳ Open Hardware
 - ↳ Mods And Hacks
 - ↳ Products FAQ
 - ↳ Tips & Tricks
 - ↳ Discuss & Help
 - ↳ Windows
 - ↳ MAC
