Hi everyone. Built and been printing using the Delta G2S Mini Pro for a few months just getting used to the temp/flow settings. Printing odds and ends for a project I am working on. Just today I moved one of the hot end cables upwards while it was heating up and it switched off, LCD blank. Obviously I checked the two wires that go into the heating element and separated them as I thought that they touched and shorted out the connection. Tried a few times to start it with no luck/ LCD blank. Has anyone experienced this and can advise what I can do to reset the board?
Thanks a lot!
Delta G2S Mini Pro - GT2560 not powering up
Re: Delta G2S Mini Pro - GT2560 not powering up
Hello all! I did some investigation and identified 2 board fuses. A 10A and 15A. The 10A was blown and this corresponds to my problem. I have ordered a replacement and hopefully will be back in action next week.
Hope you can solve your problem.
All up and running thanks.
