Y AXIS belt is not straight
When assembling the belt for the y axis the belt is not straight it basically makes a triangle and I am not sure why this is. Is there some end supports on backward?
- Look at the belt.
- Q7iJoGzV-12665770.jpg (338.24 KiB) Viewed 6674 times
Newopint95
Re: Y AXIS belt is not straight
what printer are you building? you may have yout Y axis motor pointing the wrong way.
Hi,the assembling of Y axis motor may have some problems,please double check the assemble manual.
