G2S Pro Height calibration issue
dbranded
Post by dbranded »
I was trying to calibrate my g2s pro.
I was following the instruction manual.
I set the print height at 200mm. I tried to bring the Z-axis down to zero, but the print head started grinding into the bed. It was good down to 10mm and then when it hits zero it just didn't stop.
The manual said there should be a 10mm space between the print head and bed, but it just grinds into my bed at Z-axis (0). I don't know if I should try to set the height to 210 as the manual says to do.
Should I set the print height to 190? I'm not too sure what to do in this situation.
Please let me know if you guys have run into the same issue or have any suggestions.
Re: G2S Pro Height calibration issue
Hi,in your case,the height maybe small,you should try to set the height to 210 or even higher.By the way,you can refer to this video to do that:https://www.youtube.com/watch?v=VCa_Bvx ... o1VV2ioejQ.Of course, this is only a reference, you need to adjust it according to your actual situation.
