Hello
I am a new acquirer of the AI3Pro printer with 3D Print Control Box. I received the printer with 2 A498 controllers in blackouts. The worry is not the. So I proceed to their replacement is finally start Use this one.a second day of use the Box lost the firmware? After the information received very quickly not your technical services I reloaded the following firmware:
4) For prusa I3 A Pro with the 3-in-1 3D printer control box:
PI3A Pro.zip prusa I3 A Pro (375.46 KiB) Downloaded 1923 times.
So I loaded this firmware with Easy print because it does not work with Arduibo is Merlin.
Result This software has important errors to know:
Values of X steep mm (replace directly in the box by the value of +085.32)
Y steep mm (given the same value of +085.32)
Z steep mm (which was a +400 (replaced by 2650))
E steep mm (which was +093 (replaced by +0480))
I am not sure that my values are the best adapted but it has resumed a functionality of Z and an Extrusion almost a 100mm.
Question:
1) Is there a firmware adapted to this machine if yes can you send it to me?
2) Can your loader this software by Arduino 1.0.6? Or I have to use Easy print.
3) How to put the French language in the firmware because via the loading by Easy print it is impossible to do it.
4) Summary: If there is the right software for this printer can you tell me how to get it and how to set it up in the machine and the procedure for the complete installation in French thank you for reading me
best regards
Jean Pierre
Bonjour
je suis un nouvel acquéreur de l'imprimante AI3Pro avec 3D Print Control Box .J'ai reçut l'imprimante avec 2 contrôleurs A498 en pannes .Le soucis n'est pas la.J'ai donc procéder a leur remplacement est enfin commencer a utiliser celle ci.a second jour d'utilisation la Box a perdue le firmware ? Suite aux renseignement reçut tres rapidement pas vos services techniques j'ai rechargé le firmware suivant:
j'ai donc chargé ce firmware avec Easy print car cela ne fonctionne pas avec Arduibo est Merlin.
Résultat ce logiciel comporte des erreurs importantes a savoir :
Valeurs de X steep mm (remplacer directement dans la box par la valeur de +085.32)
Y steep mm (remis la meme valeur de +085.32)
Z steep mm (qui était a +400 (remplacé par 2650))
E steep mm (qui étais a +093(remplacé par +0480))
Je ne suis pas sure que mes valeurs soit les mieux adaptées mais cela a permis de retrouver une fonctionnalité de Z et une Extrusion quasi a 100mm .
Question :
1) Existe t'il un firmware adapté a cette machine si oui pouvez vous me le faire parvenir ?
2) Peux ton loader ce logiciel par Arduino 1.0.6 ? ou suis obligé de me servir de Easy print .
3) Comment mettre la langue française dans le firmware car via le chargement par Easy print il est impossible de le faire .
4) Résumé : si il existe le bon logiciel pour cette imprimante pouvez vous m'indiquer comment l'obtenir et comment le mettre en place dans la machine et la procédure pour l'installation complète en français merci de me lire
Jean Pierre
Firmware for AI3Pro printer with 3D Print Control Box
Re: Firmware for AI3Pro printer with 3D Print Control Box
Hi,you can use Arduino 1.0.1 to upgrade the firmware by the following post,please take a look:http://www.geeetech.com/forum/viewtopic ... 20&t=17046.
Thank you very much for your answer
I realized the addition of the patch U8GLIB in the library of Arduino 1.0.6
. I put the French language in the merlin and I succeeded to make the upload of the original program in the 3D Printer Controle Box. I have only the configurations to realize to obtain a good printing quality Thank you again for your information
Greetings Jean Pierre
It's my pleasure to help you.f1umo wrote:William
Greetings Jean Pierre![]()
