3D Touch invert Z
slipknot28
3D Touch invert Z
Post by slipknot28 »
I have a problem with setting 3D Touch. I tried with every firmware that I found. I also tried with a capacitive sensor. 3D Touch and Capacitive Sensor work smoothly. After the G29 command I get the measurement results. Thereafter a problem occurs. At a point where the head should go down, it raises and vice versa. I've read all the possible forums and nowhere did find the solution. I've seen many people have such a problem.
I would be grateful if someone could solve this.
Re: 3D Touch invert Z
Hi,could you send a video showing how does it work?
slipknot28
Because I set bed leveling manually there is no point of taking video.
Now on video you can not see anything. I really do not want to readjust bed again to make a video.
My Z offset iz set to -1,4 with M851 command (also tried set it trough configuration.h file).
These are readings after G29:
08:51:43.742 : Bilinear Leveling Grid:
08:51:43.742 : 0 1 2 3
08:51:43.742 : 0 -0.20 -0.23 -0.39 -0.65
08:51:43.742 : 1 -0.27 -0.31 -0.40 -0.62
08:51:43.742 : 2 -0.31 -0.29 -0.40 -0.54
08:51:43.742 : 3 -0.24 -0.25 -0.37 -0.57
08:51:43.742 : X:142.00 Y:194.00 Z:11.61 E:0.00 Count X:11360 Y:15520 Z:28672
I really do not understand what is the problem.
