Geeetech i3 pro B with NinjaFlex
pedrosc1967
Post by pedrosc1967 »
I would like to know if this printer is able to use the NinjaFlex filament:
https://ninjatek.com/products/filaments/ninjaflex/
Have you used it?
What parameters did you use?
Regards - Pedro
Re: Geeetech i3 pro B with NinjaFlex
Hi,maybe you can have a first try ;) .I find some related printing guidelines in the link you send:
"Extruder Temperature: 225°C – 235°C
Platform Temperature: Room temperature – 40°C
Glue and/ or blue painters tape is suggested if not using a heated bed.
Print Speed:
Top and bottom layers: 10-20 mm/ sec (600-1200 mm/ min)
Infill speeds: 15-35 mm/ sec (900-2100 mm/ min)
Layer 2+ use cooling fan if available."
Soadyheid
Post by Soadyheid »
Check out this YouTube video, very interesting!
https://www.youtube.com/watch?v=KBbsDQWfrwA
Play Bonny!
Soadyheid
