After changing the GT2560 board on Geeetech i3 Prusa pro B and loading correct fimware the LCD screen does not show all the info and does not control printer.
Is there more firmware needed for "LCD 2004" ?
After changing GT2560 and loading firmware the LCD screen
Re: After changing GT2560 and loading firmware the LCD scree
Hi,I wanna know which version of GT2560 are you using and how do you upload the firmware?
I suggest you to upgrade the firmware with EasyPrint 3D.
Here is the download link:
http://www.geeetech.net/firmware/EasyPrint.msi.
And here is the instructional video you can refer to
:https://www.youtube.com/watch?v=U3ua4vM ... pqufTgHOgE.
Hope it can help you.Please let me know the latest situation after that.
Hi William
I used Arduino 101 and used the firmware from the Geeetech forum for Geeetech I3 prusa pro B
But for some reason that firmware is missing the info needed to make the LCD 2004 work correctly
The board that I am using is GT2560 rev.a
I really do not want to use Easy Print. I am happy with program I have
Thanks any way
I just need the firmware for LCD 2004
Thanks any way
Ok I have tried the Easyprint but it made no difference
Is there any body there that can tell me what I can do to make my LCD 2004 controller work correctly ?
I think the LCD controler may have some problems instead of firmware.Could you take a video about the LCD issue as much more detail as possible? It will be more clearer and easier to find the key point.You can upload the video to Youtube or something like that,then just send the video link in this post.
Re: After changing GT2560 and loading firmware the LCD screen
I have connected my old board to the printer and the LCD works correctly so there has to be some part of the uploaded firmware missing for LCD in the Geeetech I3 Prusa Pro B that I used for the new board GT2569 rev A+.
And I did use the firmware from Geeetech forum for Geeetech I3 prusa Pro B
