just recently the timing belt for the x axis broke down on my mecreator2. Sadly i havent found any good tutorial on how i can fix this or even better replace the whole belt. Can you provide some kind of tutorial on your wiki or even a youtube video which can guide me through the process?
Best Regards,
Gamura
How-To Replace Belt on X-Axis on Mecreator
redirect303
Re: How-To Replace Belt on X-Axis on Mecreator
Indeed some instructions would be useful for replacing the X-axis belt on MeCreator2.
From what I could see, the belt is fastened under the carriage with some plates and screws from atop. I assume the entire extruder assy has to be removed in order to tamper with the belt.
Also, there doesn't seem to be any tension method for the X-belt...
If any admin reads this, would be appreciated to have a bit of tutorial on this one.
Hi, thanks for your feedback.
