Problem programming mini 168 with usb
quinzico
Post by quinzico »
Hi, i've bought 2 geetech mini168 and the usb converter. The Converter is this one:
and the Mini is this one:
There is a connection schematic in the website :
I've tried the 2 connection types but i couldn't programm my mini168. It allways give the error that i show in the "error_mini.jpg" file (in the attachments). My latest connection you can see on the files mini1,jpg, mini2.jpg and mini3.jpg. I've chose pro mini 5v,16MHZ w/ ATMega168, but it allways give's the same error. I've tried to push the reset button, and nothing, can anyone help me?
error mini168
error mini168
jack
Re: Problem programming mini 168 with usb
Post by jack »
Hi friend,
Please keep pushing the reset button on Pro Mini, then upload your sketch.As soon as the LED on the USB converter flash, release the reset button.
Regards,
Jack
quinzico
Post by quinzico »
Thanks for the reply, but i've made that and doesn't work. Do ineed a seperate power supply to program it?
quinzico
Post by quinzico »
Hi, i've tried to programm my second mini and works fine. I think the fisrt one is damaged.
dimaris
Post by dimaris »
Hi, I bought four geetech Pro Mini Atmega 168 5V/16MHz and transmitter Nano USB converter module. Did not get to program, shows the same error. The driver is fresh, checked all the same port, 19200. Tell me what could be the reason? What am I doing wrong? This is my first steps as Arduino, please help.
jack
Post by jack »
jack wrote:Hi friend,
Regards,
Jack
dimaris
Post by dimaris »
Hi, no problem! geetech Pro Mini Atmega 168 5V/16MHz was intact. The reason was Nano USB converter. Poorly soldered a 1 contact (TXD) FT232RL, soldered and everything just worked! Thanks for the advice!
jack
Post by jack »
Hi Dimaris;
It's good to know that you have solved the problem. Good luck with your project buiding.
regards,
Jack
