problem install win ce to mini 2440
techsupport
Re: problem install win ce to mini 2440
Post by techsupport »
Hi friend,
Do you install the USB driver in PC and specify the address 0x30000000 in DNW - USB port downloading address? http://www.geeetech.com/wiki/index.php/ ... n_Mini2440
Regards;
Techsupport
Email: forum@geeetech.com
techsupport
Hi friend,
Do you install usb Download driver properly http://www.geeetech.com/wiki/index.php/ ... n_Mini2440?
A damaged image file might also cause this problem, which type of the display come with the board? I can upload the related files to you.
Regards;
techsupport
techsupport
cvas
Post by cvas »
i tried to install linux and its work
i tried to upload the test2440 and its work
why i cant upload win ce ;
what i miss its any other way to upload win ce ?
can i use other bootloader ?
i try to find anything in net but i cant find anything test it?
please give me any instractions ?
cvas
Post by cvas »
I try it and i get the same
The problem seems to be something with the addresses on flash memory for the win ce
Because all other OS and test application can be upload to NAND.
Its possible to send me a backup of a NAND flash memory with ce and try to unload via usb to mine board?
When I format with “ f” option in first dots I get an “|”
Enter your selection: f
It’s that ok it means something ?
i am waiting your instractions
thanks
techsupport
Hi friend;
May be it's the problem of the Nand Flash. Please leave me your ebay user ID via email, our customer service unit will contact you for the product repairing or the replacement.
Regards;
Techsupport
