I am a newbie to 3D-printing and have bought a Me Creator 2. I have a question about before I started printing with SD-Card.
The user manual tells me:
“Home position is in the right back corner of the printing platform.“
This is the same point I get with “Auto Home“ in Me creator 2 “Prepare“ menu.
With Repetier-Host: "Note: the origin point is the left front corner of the platform when printing. So when the printer is at home position, the coordinates of X/Y axis are: X=160mm, Y=160mm, Z=0mm."
Now my questions:
- Must I before every printing calibrate with Repetier-Host the origin point at the left front corner manually, no matter I use USB or SD-Card?
- Can I save this settings anyway to Repetier-Host?
- Is there a way to automate this with modified g-code and Me Creator 2 get the movement to origin point from g-code without “homing“ in Repetier-Host manually?
With regards
hotten64
Me Creator 2: Home- and Origin-Point
Re: Me Creator 2: Home- and Origin-Point
It is ok ,you need not calibrate the origin point to the right back corner ,because the printer will do it automatically before starting printing.
I've got something strange, when Iask the printer to go home it tells me X 175 Y 165 Z0.
is it normal ?
Thank you
Thierry
is it normal ?
Thank you
Thierry
Have you enabled 3D touch functionality in the firmware?
hello
I don't think so. I've never been told about this. How can I do this. The came with the firmware loaded.
Thank you
Thierry
Thank you
Thierry
Hello, I also have a Me Creator 2 since yesterday. now I also have the problem that my home position is at X175, Y163, Z0. how can I solve the problem? I already tried that with the offset in repetierhost, and also starting x10 and y10 and then set home offset. but that doesn't work.
please help me
please help me
You can download the firmware from this link: viewtopic.php?f=20&t=17046MucMoe wrote: Wed Jul 11, 2018 3:14 pm Hello, I also have a Me Creator 2 since yesterday. now I also have the problem that my home position is at X175, Y163, Z0. how can I solve the problem? I already tried that with the offset in repetierhost, and also starting x10 and y10 and then set home offset. but that doesn't work.
please help me![]()
Try to edit the code:
Code: Select all
// Travel limits after homing
#define X_MAX_POS 175
#define X_MIN_POS 0
#define Y_MAX_POS 165
#define Y_MIN_POS 0
#define Z_MAX_POS 161
#define Z_MIN_POS 0
Code: Select all
#define X_MAX_POS 160
#define X_MIN_POS 0
#define Y_MAX_POS 160
#define Y_MIN_POS 0
#define Z_MAX_POS 160
#define Z_MIN_POS 0
