Hellou.
I need help to update my firmware on my printer. I have laptop what is connected to printer and port is works fine and repertier software print well. I install new z axe rods and i need to fix new stepper setup to firmware. Anduiro 1.0.1 updated done firmware but nothing still not change printers firmware. What to do? Anduiro board setup is correct and port is correct
I3X Firmware broblem
Re: I3X Firmware broblem
You are able to update directly the firmware via Easyprint .
Okei. I have to try that today.
Easyprint even not can update firmware. Software cant find firmware but its say installed firm is some merlin and printer is D200..?
You are supposed to choose the right models and serial numbers of printer in easyprint that contributes to updating firmware properly .
I tried right models bus same result. Were i find serial numbers in software and printer?
