Hello. I'm asal arbatani. I live in Iran and have a 3D printer Delta Rostock mini G2s have not been assembled. We assembled it and connected it with a computer using the repetier program. But we encountered problems.
Firstly, the micro switch does not command the nozzle to not to hit the plate. Where to put the micro switch cable to work properly? Second, we insert the SD card into the device. The printer knows the SD card but can not execute files inside the SD card. How can we fix this problem?
please answer my questions as soon as possible.thanks.
problems of 3D printer Delta Rostock mini G2s
asal arbatani
Re: problems of 3D printer Delta Rostock mini G2s
1.Double check the connections of the end stop.
2.The SD just can detect the G-code file.
