Hello, is there any solution for the plastic extruder?
it need to push filament by hand in order to extrude the correct amount
i have set the filament diameter in slicer correctly i think at 1.75mm
filament need to push by hand in order to extrude correctly
Re: filament need to push by hand in order to extrude correctly
Some points about your issue.panzo wrote: Tue Aug 29, 2017 5:08 am Hello, is there any solution for the plastic extruder?
1. the extruder can work when the temp is above 180 degrees.
2. Maybe the nozzle is clogged and you have to clean it.
You can refer to this video to clean it.
https://www.youtube.com/watch?v=3iS8YU_TNEw
3. Maybe the A4988 has not enough power to drive the extruder turn.You should increase the driver voltage of A4988 to 1V.
And you can refer to this post.
4. Maybe the distance between the nozzle and the bed is too close. You should increase it.
5. Maybe the feeder is bad. You can refer to this post to check.
http://www.geeetech.com/forum/viewtopic ... 19&t=18507
Btw, the video for extruder calibration.
https://www.youtube.com/watch?v=fb7lit5 ... e=youtu.be
Filament needs to push by hand in order to extrude correctly. If you do not extrude correctly then you take some fixing https://www.superiorpapers.com/buy-admission-essay.php issues. If you know then it is easy for this to fix it. But if you don't know then you need to go to that guy to have the ability to fix this.
anshikajii
I feel really glad to have seen your page and expect such incalculable even more fabulous and extraordinary food groupings here. Much appreciated again for the entirety of the subtleties.
Female escorts in Delhi
