prints circle as polygon
panzo
Post by panzo »
hey does anyone experience the following problem my i3 prints circle as polygon
Newopint95
Re: prints circle as polygon
Post by Newopint95 »
do you have a picture of your print?
panzo
Post by panzo »
yes is the printed item of the photo from the following file from thingiverse
https://www.thingiverse.com/thing:2263762
Newopint95
can you send me the gcode you used? the problem may be the .stl not your printer.
do you know what the settings are on your printer? speed, steps per mm for x and y, etc.
does this happen with all circles?
try printing this quick test print and see what you get.
https://www.thingiverse.com/thing:1023717
panzo
Post by panzo »
same and in this file..... circle sliced as polygon
bellow you can find gcode
https://www.dropbox.com/s/rjizi7tv8k04n ... e.rtf?dl=0
is there any other software that can communicate with my printer via usb?
panzo
Post by panzo »
problem solved it was the mac application faulty i have slice it in windows and everything is ok
